K kmaster Member Joined Dec 29, 2007 Messages 11 Points 55 Location drogheda Sep 9, 2011 #1 can anyone tell me are there 1 or 2 rings are between the top mount and the lower mount
Shadeyman Patron member Written a guide Joined Sep 29, 2008 Messages 6,174 Points 1,379 Location Wolverhampton Sep 9, 2011 #2 Hello and welcome to the forum. Could you be a bit more specific, what mounts are you refering to?
OP OP K kmaster Member Joined Dec 29, 2007 Messages 11 Points 55 Location drogheda Sep 9, 2011 #3 top and lower mounts on front suspension
OP OP K kmaster Member Joined Dec 29, 2007 Messages 11 Points 55 Location drogheda Sep 9, 2011 #4 between 5 and 10
Shadeyman Patron member Written a guide Joined Sep 29, 2008 Messages 6,174 Points 1,379 Location Wolverhampton Sep 9, 2011 #5 Item 10 is the ring, item 5 is the top pad. There should be a bearing in item 10 that allows the strut to turn when steering. Attachments 9999.jpg 50.6 KB · Views: 29
OP OP K kmaster Member Joined Dec 29, 2007 Messages 11 Points 55 Location drogheda Sep 9, 2011 #6 thanks bought new top and lower mounts and got bearing with the 2 of them
Davren Moderator Staff member Uploaded 10+ resources/downloads Joined Jul 6, 2008 Messages 16,365 Points 3,858 Location London, UK. Sep 9, 2011 #7 There should be 1 bearing between the top and bottom rubber mountings. The bearing consists of 2 rings with rollers between them. The bearing clips onto the lower mounting and must be fitted the correct way up as in this diagram. . Attachments Spring Top Mounting.JPG 55.8 KB · Views: 39
OP OP K kmaster Member Joined Dec 29, 2007 Messages 11 Points 55 Location drogheda Sep 9, 2011 #8 thanks for that hope i get it right
