hanzs
on my 1,6 Stilo the MIL light came on, 2 days ago.
So I read the faults with FES:
Pre-cat O2 sensor - low signal
So I did livedata graph of pre-cat and post-cat O2 sensors on idle. (att. below).
And you can see some down spikes to the value 0,00V. This is not normal, it schould oscillate between cca 0,15-0,8V. It was ok in past (I have older graphs), it now started.
I'm not sure what does it mean - car still running fine, with full power, no cutting there.
These down spikes indicate too much oxygen in exhaust, it can be caused by misfires (but I dont feel them) or maybe by dirty injectors? Because dirty injector = less fuel = not every oxygen in cylinder is burned??
What do you mean?
What do you mean?
