I did . I changed the bulbs although something went horribly wrong causing the bulbs to blow in one headlight but the indicator which wasn't blown but didn't work. Got it tested with a meter and there was some creepy problem in the wiring of the headlight so we just got a second hand headlight and everything worked fine again! Could be the same problem, have you recently changed any bulbs ?
