Note: The owner of the user 'ufukata now. Instead, the new taþýnmýþtýr Management.
Cd player and popped in my CD player, such as different olduðunu saw Fatih.
Two 3.5 mm male jack tip ends of the cables are cut and took off one end of the cable.
3 cable HE. Red-white and uncoated cable. Red and White Right and Left, overlay the Beam Pozitioners that.
They like the image of the CD player behind the socket so I spent Yellow Green.
CD player plugged into the headset automatically goes PHONE mode. Çýkarýnca earpiece is returning to normal. PHONE BASS-TREBLE mode, that can adjust the FRONT-BACK AND LEFT-SAD.
Sound quality is near CD quality. No buzzing, etc.. MP3 player and Nokia 5800 baðladým beklediðimden both very very good sound quality.
With trial and error, I did modify a few. Opening in the tape as soon as you insert the tape input on the headset automatically. (Phone mode). Mp3 thirds remained open if switched off the tape çýkarmayýnca earpiece.
Among 'on-off switch in the picture I added the pins 9 and 12. Because the short-circuit yaptýrýnca exceed 9 and 12 are opened PHONE mode. Red and white wire from pin 7 of Jaktan birleþtirip, the only remaining cable baðladým pin number 8.
Now I use the system to turn off switch.
