Right then i was minding my own damn business on friday with the air con on and the fans on '4' all of a sudden all the fans went dead
I can't use speeds 1, 2, 3 or 4 everything else in the console seems to work fine, its a manual unit with the dials, NOT the auto climate control jobbie.
I've checked T08 (under the battery cover in the bonnet, swapped it with 2 other relays in there all seems ok) and fuse 31 (in the dash) for the 'reverse lights' and fuse 8 (also under the battery cover) still no luck.:bang:
I took the side panel off the tunnel today and had a look round, found a relay up there, dunno what its for. (next to the motor housing but secured on the cage around the steering column i think
i was upside down kinda hard to tell)
Whats this brown connector in regards to the scematic?
Also should i be checking here for a feed to my motor? (blue and brown wires in the back of the fan housing, probably a stupid question just don't wanna probe anything I shouldn't
