Old 10-05-2011   #1
Lithuania
Boost pressure
Hello,
I own a Stilo 1.9JTD (85kW - 115HP), recently it has lack of power. I've connected FiatECUScan, and noticed that boost pressure and desired boost pressure is very different (see picture attached). I cannot find anywhere what boost pressure should normaly be. So is it normal, or my turbo is faulty? Could it be that boost pressure solenoid is faulty?
P.S: Sorry for my poor English
Mazhasai is offline Reply With Quote Quote
Old 10-05-2011   #2
sussexa has donated!
Re: Boost pressure
if that figure is actual boost, it works out about 20psi which must be around normal good level of boost if not higher than expected for a 115bhp.
if its map pressure its quite low take off atmospheric = 5 psi
has it got any problems?split hoses, boost leaks,stuck egr?
sussexa is offline Reply With Quote Quote
Old 10-05-2011   #3
Trader Rating: 7
Shadeyman has donated!
Re: Boost pressure
On the 3 cars I've checked "Boost" against "Desired Boost" - boost has always been slightly higher than desired boost so IMO you have a problem. Faulty boost solenoid, cracked hose, faulty MAP sensor etc.
What the boost presure should be varies according to throttle possition etc.
Shadeyman is offline Reply With Quote Quote
Old 24-05-2011   #4
Lithuania
Re: Boost pressure
Changed boost pressure valve/solenoid - the problem is gone
(T) croma boost pressure buster Croma 0 07-04-2011 18:59
(T) Boost Pressure Signal oneoneeight Bravo 1 23-10-2007 11:25
(T) tempra td boost pressure cabs Tempra 9 01-04-2007 21:13
(T) boost pressure loss blinkyspoogle Coupe 4 13-01-2007 19:30
(T) Boost pressure syrill-sneer Uno 4 25-08-2005 16:56
