Old 09-04-2011   #1
air con efficient?
Hi all, how can I check how efficient my air con is?
Am I expecting too much, how cold should it be and how can I test it myself?
It does get cold, but I dont think its not cold enough, but I have only had the car a year (56 plate MW 1.9 Diesel multijet 8v)
Any help would be appreciated.
Cliff
cab is offline Reply With Quote Quote
Old 09-04-2011   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: air con efficient?
I'd check the temp of the aircon cold pipe at the bulkhead with cabin fan off. If it can get down to 4C then it's doing well.
You need to use the recycle switch to stop hot air coming in all the time otherwise your A/C is working overtime cooling new hot air rather than continually reducing the temp of the existing cabin air. After that you need a decent cabin fan airflow so check your cabin filter isn't blocked.
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 09-04-2011   #3
Yellow Peril has donated!
I find the air con needs a top-up of refridgerant every two years to keep it at its best. And no, I don't have a leak...
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 10-04-2011   #4
Moderator
gadge's Avatar
gadge is part of the official FF Events Team :)
gadge has donated!
i heard from an air con specailist once that the coolant used in the air con gas has a some kind of oil in it which is supposed to coat the hole inside of the air con system preventing gas from escaping when its not been used? appartently if u use it every 3 months for 10 minutes it should last years ........... incidently, mine needs doing aswell because i have the same problem
gadge is offline Reply With Quote Quote
Old 10-04-2011   #5
Deckchair5's Avatar
It's very rare for air con systems to be completely gas tight. The flexing on engine movement, the large temperature changes from very hot to near freezing, and pressures from 15psi to 200 psi then it's a lot to expect. Oil is largely there to lub the compressor, lub the seals and prevent corrosion
99 Bravo 1.2SX
Old 10-04-2011   #6
Moderator
gadge's Avatar
gadge has donated!
it makes sense really, its alot to ask that it stays all tight in there. I i had to re-gas both my marea and my ford ka and now it looks like i'll have to do my stilo too? i guess over time, its one of those jobs that need doing from time to time
(T) Noisy Air-Conditioning (air con) Advice wanted caprimancars Punto (Mk2/2b) 1 29-06-2009 20:52
(G) Air Con Condensor con?! Camblet Stilo 8 22-03-2009 02:48
(T) Is it possible to fit air-con to a non air-con coupe? Pauly20vturbo Coupe 5 06-11-2008 14:27
(T) Stilo Active Air Con - No Air Con andrewduerden Stilo 8 11-05-2008 19:15
