Hi all
Can anyone provide me with any of their Fiat ECU scan parameter readings ? This is purely for comparison purposes. I have some ongoing issues and I just need to eliminate bit by bit parts and components in the way.
These are my readings via Fiat ECU scan, can anyone or does anyone know if these readings are normal or abnormal?
FUEL PRESSURE – 300 BAR
FUEL PRESSURE SIGNAL – 1.30..V
FUEL PRESSURE REGULATOR – 15.77%
BOOST CONTOL SOLENOID – 75%
BOOST PRESSURE – 1.028 M.BAR
ACTUAL EGR – OPERATING RATE - 1%
ENGINE TEMPERATURE – 81.6 c`
ENGINE TEMPERATURE SIGNAL – 1.408 VOLTS
Any input will be most appreciated
