mad max 2
Fiat Stilo with big problems help needed, it is a bit of a long story so bear with me. car dropped a cam belt, removed head found it in uneconomical repair, so installed 2nd hand engine. previous to this the map wires had burnt through on the exhaust, now 2nd hand engine fit, nothing but trouble, running lumpy on idle after warmed up runs perfect cold? cleaned throttle body out to no avale, doesnt seem to be a signal to the black wire on lamber sensor pre cator post cat, could it possibly be a ECU problem. thank you
