Technical stilo with big problems help needed
Just had another thought (dangeros) i know .If i riged a bulb up as a test lamp would this idea work to check earths from ecu?
I just use multimeter set on resistance or many now have buzzer circuit tester. This won't test if you have a short from one wire to another if you have burnt wire insulation or crushed wiring but you seem to have no connection at all to earth
If no joy would it be possable to have ecu checked out any where?
Plenty of places around. ECUdoctor etc
According to eLEARN, connector B (M10B) for the 1.6 engine ECU is on the right viewed from the front of the car.
Pinouts for connector B are shown in the second diagram. Be very carefull when probing the pins and sockets, they are very delicate.
