Old 18-02-2011   #1
Trader Rating: 7
Shadeyman has donated!
Proxi-alignment failure.
My climate control was playing up so I brought a second hand one for 10.
I also brought a broken set of clocks(speedo etc.) because the clear plastic on the front of mine had a few small scratches from where I had thrown my keys.
Once I'd swopped them over and reinstalled them the mileage was flashing(as expected) so I fired up FiatECUScan and found:
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
Body Computer Node (NBC):
Dashboard Node (NQS):
Climate Control Node (NCL):
Started the Proxi-Alignment and it Failed.
Here's the log file.
Reading CAN configuration data ...
CAN CONFIGURATION DATA:
00 02 07 DF 00 02 07 DF 00 02 04 02 00 02 04 02 00 00 00 00 00
00 02 07 DF 00 00 04 09 00 02 07 DF 00 00 04 09 00 00 00 09 00
30 34 31 39 32 30 32 35 33 33 39 54 45 52 4D 3A 33 34 20 20 20 20 05 02 14 DF 07 02 00 09 04 00 00 F3 00 00 00 00 85 26 07 00 02 44 06 00 00 00 00 00 00 00 11 58 53 00 00
CURRENTLY CONFIGURED CAN MODULES:
Engine Control Node (NCM)
Electric Steering Node (NGE)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Info-Telematic/Convergence Node (NIT/NCV)
Driver Door Node (NPG)
Boot Node (NVB)
Passenger Door Node (NPP)
CURRENTLY AVAILABLE CAN MODULES:
Boot Node (NVB)
18/02/2011 18:34:40
CONNECTED TO:
FIAT STILO 1.9 JTD
CAN Setup / PROXI Alignment Procedure
CURRENTLY CONFIGURED CAN MODULES::
Engine Control Node (NCM):
Electric Steering Node (NGE):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Info-Telematic/Convergence Node (NIT/NCV):
Driver Door Node (NPG):
Boot Node (NVB):
Passenger Door Node (NPP):
CURRENTLY AVAILABLE CAN MODULES::
Boot Node (NVB):
EXECUTING ADJUSTMENT...
Writing CAN configuration data ...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Dashboard Node (NQS)SUCCESS!
Writing to module: Climate Control Node (NCL)FAILED!
FAILED TO EXECUTE
Climate Control Node FAILED.
Double checked the connections, everything looks ok.
Anyone got any ideas why this might be happening?
Shadeyman is offline Reply With Quote Quote
Old 18-02-2011   #2
Trader Rating: 7
Re: Proxi-alignment failure.
Problem solved. Well, sort of solved.
I contacted Yani(FiatECUScan owner) as I couldn't find anything relating to my problem.
Here is his reply.
Unfortunately, there is a problem exactly with this module which I don't know how to fix, yet.
The PROXI Alignment Function ALWAYS fails for Stilo Climate control node. I don't know why. There is nothing in the documentation about this problem. Also, it fails most of the times on Alfa 147 Instrument Cluster node. There are no problems with the other vehicles.
I'm trying very hard to resolve this problem but I have no success yet.
Regards,
Yani
So, a Fiat dealer is my only choice.
Old 25-08-2014   #3
Romania
Hi.There's any changes in this problem? I have same problem....
bebeluka is offline Reply With Quote Quote
Old 25-08-2014   #4
Sweden
Me too.
Greatfull for a solution!
Jonny Wallin is offline Reply With Quote Quote
Old 25-08-2014   #5
dave's Avatar
Trader Rating: 10
dave has donated!
Quote Originally Posted by bebeluka View Post
Quote Originally Posted by Jonny Wallin View Post
Me too.
are you using the latest paid for versions of multiecuscan?
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 26-08-2014   #6
Romania
No.I use a free version of Multiecuscan..
Do u think the paid version make the differences?
Old 26-08-2014   #7
mhowse has donated!
Also join the club of proxy failing on climate control, had a play about with it the other week at first tried it with climate panel switched off and it failed so thought try with it switched on still failed but gave it another couple of more tries and it completed the proxy alignment fully, well that is what the computer siad so left and all items in car work as should with cruise control added from alfa stalk. am using registerd version multiscan with modified usb elm .
mhowse is offline Reply With Quote Quote
Old 27-08-2014   #8
Sweden
Quote Originally Posted by dave View Post
Hi!
Yes, I have the fully paid one. I also tried the latest version.
It fails on the clima-unit that I have swapped out on my Abarth and everything else works in the program.
I have a flashing road trip meter.
Not so pleasant to have, the day I sell the car.
Grateful for a solution.
Old 27-08-2014   #9
dave's Avatar
Trader Rating: 10
dave has donated!
maybe Yani still hasn't found an answer then, anyone asked on his forum? http://forum.multiecuscan.net/
(T) ESP Failure & Hill Hold Failure VegaUK Punto (Mk2/2b) 6 23-01-2010 21:33
(G) Parking sensor failure, air bag failure AND speeding ticket :( cuppycakes Stilo 10 06-09-2008 13:47
(T) Engine Control System Failure and Power Steering Failure oc99 Punto (Mk2/2b) 2 18-05-2008 14:54
(G) ABS failure EBD Failure Switch off engine Call Garage Handbrake lamp on SillyBilly Multipla 0 15-03-2008 21:16
(T) Proxi Alignment Failure - Abarth Dash larzmaster Stilo 7 19-08-2006 15:50
