Technical Proxi-alignment failure.
Wolverhampton
My climate control was playing up so I brought a second hand one for £10. :D
I also brought a broken set of clocks(speedo etc.) because the clear plastic on the front of mine had a few small scratches from where I had thrown my keys. :doh:
Once I'd swopped them over and reinstalled them the mileage was flashing(as expected) so I fired up FiatECUScan and found:
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
Body Computer Node (NBC):
Dashboard Node (NQS):
Climate Control Node (NCL):
Started the Proxi-Alignment and it Failed. :(
Here's the log file.
Reading CAN configuration data ...
CAN CONFIGURATION DATA:
00 02 07 DF 00 02 07 DF 00 02 04 02 00 02 04 02 00 00 00 00 00
00 02 07 DF 00 00 04 09 00 02 07 DF 00 00 04 09 00 00 00 09 00
30 34 31 39 32 30 32 35 33 33 39 54 45 52 4D 3A 33 34 20 20 20 20 05 02 14 DF 07 02 00 09 04 00 00 F3 00 00 00 00 85 26 07 00 02 44 06 00 00 00 00 00 00 00 11 58 53 00 00
CURRENTLY CONFIGURED CAN MODULES:
Engine Control Node (NCM)
Electric Steering Node (NGE)
Steering Wheel Controls Node (NVO)
Brake System Node (NFR)
Info-Telematic/Convergence Node (NIT/NCV)
Driver Door Node (NPG)
Boot Node (NVB)
Passenger Door Node (NPP)
CURRENTLY AVAILABLE CAN MODULES:
Boot Node (NVB)
18/02/2011 18:34:40
CONNECTED TO:
FIAT STILO 1.9 JTD
CAN Setup / PROXI Alignment Procedure
CURRENTLY CONFIGURED CAN MODULES::
Engine Control Node (NCM):
Electric Steering Node (NGE):
Steering Wheel Controls Node (NVO):
Brake System Node (NFR):
Info-Telematic/Convergence Node (NIT/NCV):
Driver Door Node (NPG):
Boot Node (NVB):
Passenger Door Node (NPP):
CURRENTLY AVAILABLE CAN MODULES::
Boot Node (NVB):
EXECUTING ADJUSTMENT...
Writing CAN configuration data ...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Dashboard Node (NQS)SUCCESS!
Writing to module: Climate Control Node (NCL)FAILED!
FAILED TO EXECUTE
Climate Control Node FAILED. :chin:
Double checked the connections, everything looks ok.
Anyone got any ideas why this might be happening?
Problem solved. Well, sort of solved.
I contacted Yani(FiatECUScan owner) as I couldn't find anything relating to my problem.
Here is his reply.
Unfortunately, there is a problem exactly with this module which I don't know how to fix, yet.
The PROXI Alignment Function ALWAYS fails for Stilo Climate control node. I don't know why. There is nothing in the documentation about this problem. Also, it fails most of the times on Alfa 147 Instrument Cluster node. There are no problems with the other vehicles.
I'm trying very hard to resolve this problem but I have no success yet.
Regards,
Yani
So, a Fiat dealer is my only choice. :(
Also join the club of proxy failing on climate control, had a play about with it the other week at first tried it with climate panel switched off and it failed so thought try with it switched on still failed but gave it another couple of more tries and it completed the proxy alignment fully, well that is what the computer siad so left and all items in car work as should with cruise control added from alfa stalk. am using registerd version multiscan with modified usb elm .
are you using the latest paid for versions of multiecuscan?
Hi!
Yes, I have the fully paid one. I also tried the latest version.
It fails on the clima-unit that I have swapped out on my Abarth and everything else works in the program.
I have a flashing road trip meter.
Not so pleasant to have, the day I sell the car.
Grateful for a solution.
