Old 15-02-2011   #1
Brazil
connect nav+ eject problem
Guys,
I bought a used connect nav+ device and installed it with no problem. It came with v8.5 and the language was in german.
I downloaded v9.8 and burned a CD. After I inserted, the upgrade went fine but the CD doesn´t eject at the end of the process. When I press the eject button, it doesn´t respond. It simply boots and restarts the upgrade process again and again.
Any suggestion?
tks!
Roger16vturbo is offline Reply With Quote Quote
Old 16-08-2011   #2
Spain
Re: connect nav+ eject problem
Hi; i have the same problem. Did you find any solution?
jlbarri is offline Reply With Quote Quote
Old 16-08-2011   #3
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
To remove a stuck CD, you need to remove the top cover then remove the screw holding the eject motor. You'll need a T6 screwdriver for the screw.
Lift the motor up just enough so you can get a finger on the edge of the white plastic gear wheel (arrowed red) then turn the gear wheel clockwise until the CD comes out.
As you turn the gear wheel, the metal tab (arrowed yellow) should move to the left and the CD should start to come out. You can only turn the gear wheel a small amount at a time, so each time you need to release it, hold the tab so it doesn't spring back then turn the gear wheel a bit more until the CD is out.
If it's a firmware update CD, the Connect Nav+ may not recover from an interrupted update.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 17-08-2011   #4
Netherlands
Easiest way to get it out is holding the CD in place with your finger (top has to come off as described) and start the CN+ up. After three failed attempts to read the CD (cause it's not turning) the auto-eject wil spitt it out.
gr J
PS Burn a new update CD at 1 speed. Don't use this CD again.
Been there done that...Bought the T-shirt
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
(T) Connect Nav problem Reddbull Stilo 1 10-07-2010 14:16
(T) connect nav problem irashleigh04 Stilo 1 17-09-2009 00:26
(T) connect nav problem !!!!!!!!!!!!! Chris017 Stilo 2 29-04-2009 23:11
(T) Problem with connect nav+ GSMBlade Stilo 0 08-02-2007 13:27
