Old 08-02-2011   #1
Ireland
fiat stilo 1.6 16v ele fault
i am new to this... got into my stilo the other morning and the battery was dead (nothing left on the the car and battery is okay) then i jump started it and driving up the road the horn went off while driving i took the fuse out and horn still going off (It was the right fuse) the ele roof was going back and foward and the fan was staying on i had to disconnet the horn for it to stop.. Then went to the shop and came back and the battery was dead within half an hour.. Fan still on when the car is off even when the fan stops battery still going dead with nothing on..
murphy2010 is offline Reply With Quote Quote
Old 08-02-2011   #2
Whaddya mean too old?
Deckchair5's Avatar
Deckchair5 has donated!
Re: fiat stilo 1.6 16v ele fault
Sounds like you have a short circuit problem with the under bonnet fuse and relay panel B1. Been spraying some water around in there?
Name:	horn circuit relay T3.JPG
If you pull out relay T3 that will stop the horn
Relays T6 and T are the rad fan relays -don't pull those out permanently - but they're also on B1 panel so I'd look there for your problems
Has anyone installed a new head unit? Wrong wiring there will cause battery drain
02 Stilo 1.6 Dynamic 3 door
99 Bravo 1.2SX
Deckchair5 is offline Reply With Quote Quote
Old 11-02-2011   #3
Ireland
Thanks very much i had taken the cover of a few days before and driving home from shopping water must have got in cause there was a few floods on the road..
(T) Fiat Stilo 1.2 16V Engine Fault. please help! Lukesfiatstilo Stilo 1 07-11-2010 17:14
(T) Stilo 1.6 16v engine fault. Milsey Stilo 2 16-08-2010 13:02
(G) 1.6 16v stilo loosing power, engine fault..?? musicrocks1000 Stilo 15 19-07-2009 21:27
