fifeplumber57
Hi i was wondering if someone can guide me to a solution to my problem, just before new year i was getting steam coming from radiator also wasn't getting any heat in the cabin, the inlet pipe to the radiator from the thermostat would be red hot but the outlet pipe is stone cold, so i replaced the thermostat myself as thought it had kicked the bucket, after doing so it was still the same except from getting heat in the cabin now, still it didn't seem to be circulating through the radiator, bled the rad numerous times and just water came out no air, even kept it open for a bit to try draw the heat through but didn't work, got told radiator might be blocked so put some speedflush in it, but before that i blew through the inlet pipe but struggled to get right through but after the flush it was clear as a whistle, so put back together and filled up n bled etc but still the circulation problem still exists, but what i did notice was that after a good run both pipes going to rad would be real hard as if too much pressure and also outlet pipe still cold, so yesterday with the system cold i disconnected the pipe from the thermostat to see if there was coolant coming through by gently squeezing the outlet pipe of the rad and sure enough it was full, didn't come pouring out as i still had the cap on the bottle but as soon as i took cap off the coolant started flowing out the pipe, so its had a new thermostat, system flushed, bled numerous times, is there any chance it could be the water pump or could it just need pressure bled, as i don't want the head gasket to go
