We've been having a few problems with the Stilo since buying it. Nothing major but it intermittently looses power when driving and will not go on boost. This only happens for seconds at a time but can be quite off putting when trying to pull away into moving traffic.
I've gone through various threads and put the symptoms down to the EGR valve.
A few weeks ago I stripped the whole thing down to find the solenoid and valved covered in soot and it was jammed. Cleaned it all up and freed up the valve. Worked great for a week or so but the problem came back.
Yesterday I removed the solenoid whilst in situ and found that the valve was jammed again so freed it and went for a drive. Seemed ok but after 150 miles, the problem came back. Quite severe at one point lasting a few minutes on the M62 at 80mph. Had to drop down into the left lane and keep my foot to the floor to stop it dropping bellow 45mph. Came back to life though and carried on as normal.
Got me thinking as to how the valve works. Found a few threads with links to other forums explaining it. Starting to become apparent that it probably isn't the EGR valve as it only operates when the car is cruising, not under load or at idle. So why am I getting cutting out at full load when the EGR shouldn't be operating anyway?
So, I made up a blanking plate today and fit it between the corrugated pipe and the valve. Car ran noticeably rougher at idle as everyone said it would but seemed more responsive and drove fine for around 20 miles. Then I felt the dreaded loss of power. Only for a split second but definitely there.
So I'm at a loss as for what to try next. I cleaned up the MAP and MAF when I originally cleaned the EGR so assume it isn't those. Is there any way of actually testing the MAP or MAF?
Have seen a few bits and pieces about the boost valve or something but they always seem to say that an error light would come on if it was this at fault. We get nothing!
Any ideas or help appreciated!
