rogertheboris
- Aug 3, 2010
- 8
- 2
hi folks,
i've done quite a bit of research through the forum on this but would appreciate your input/backup if poss?
i have an 04 1.9JTD 115 which i bought a couple of months ago from a small dealer. having been back to them a few times without much success i decided to go to a main dealer to get the problem resolved but i seem to be spending money and not getting very far.
symptoms / history:
1) any gear from 3rd up booting it (a few miles after after starting) i'd get a large cloud of brown smoke and, occasionally (usually when wet weather) the yellow 'engine fault' light would appear with 3 beeps.
2) garage changed the 'turbo boost pressure sensor' - no change atall.
3) garage then blanked out the 'EGR valve' for elimination purposes - the smoke has been lessened greatly so assumed this was the problem.
4) driving home tonight, booted in 3rd and the 'engine fault' light was back with a vengeance along with it's chum the smoke . i gave it some more welly and power was up and down, at one point no acceleration atall but then it came back when i changed gear.
5) (wildcard! unsure if related...) very occasionally first thing the car will totally lose power, almost like it's mis-firing, the revs won't go up but after a few mins at the side of the road and after some smoke it seems to warm up and back to normal.
it's booked in to have this EGR valve replaced but (and im no mechanic), if it's been 'blanked off' wouldn't this indicate it's another independent issue?
there is no loud hissing as some seem to report (other than quite a healthy sounding low volume whistle at low speed which i presume is the turbo?).
reading through the forum, these threads seems the most likely candidates...
one titled "Egr Valve (or overboost valve?)" (2008)
and one titled "Engine fault/sensor fault JTD" (2006)
im not allowed to post URLs it as im a newb!!!
would you agree that i need to ask the garage to replace the overboost valve and that the EGR is very unlikely? im surprised the overboost valve hasn't been suggested by the garage?!
i see some people have ended up living with this type of problem but i'd like to get it resolved as im hoping to have the car quite a few years.
many thanks for a fine resource and of course a very merry xmas to you all.
cheers,
Luke :slayer:
symptoms / history:
cheers,
Luke :slayer:
