Shminkypinky
Member
Hi
My 1.6 16v is now up and running again after burning a couple of valves. The car has been run for over a week now and I am pleased - all seems well (touches wood)
However I have noticed since the engine was rebuilt the car occasionally stalls at low revs such as when slowing down at a junction - its really strange one minute its running then it just cuts out.
I have used the search tool and found references to cleaning the inlet valve which I have done which has not cured the problem.
I have also cleaned the MAP sensor - again this has not cured the problem.
I am now thinking it may be the thermostat based on Deckchairs post. I am yet to do the test ne has suggested however I have noticed the engine does not get to the temperature it used too. By this I mean the needle used to always point straight up (North) no matter the weather. However recently - last 2 years or so it has only got to north west (maybe) say between 10 - 11 on a clock face.
Could this be the problem and will it definately cause stalling probs on the stilo? why since the engine (top end) rebulid could this have started to happen? are there any other sensors that may have been disturbed that could cause these syptoms?
Also where is the engine thermostat? and does the coolant need to be replaced to change it?
Many Thanks in advance
