It's 4000rpm on the 1.6 which I'd imagine is pretty fast but remember this is optimal and you always get better mpg if you drive slower. Theory and practice break down a bit when you're not using all the power (as when climbing a hill) and you have to take account of frictional losses within the engine at those sorts of revs when driving on the flat. For instance, it wouldn't make any sense to drop a gear just to maintain 4000rpm since the frictional losses within the engine would be higher than the extra efficiency the engine is able to deliver at those higher revs (but which isn't needed as you're driving on the flat).So Argonought, i wouldnt suppose you have that information, in regards to the peak values in 5th, as i was never blessed with a car manual when i purchased my stilo. Also, do these values fluctuate as the car gets lighter due to consumption, weather etc.
Also, i've had a new exhaust put in with a big bore. My dad recons it's running rich due the residue inside the exhaust. If, my car is running rich, i assume that would have a detrimental effect to my MPG even IF im driving economically, is that correct to assume?
A simpler answer might be to say a car is being driven economically when it doesn't take much effort (in the sense of pushing the accelerator) to keep it going.
Keeping revs at 4000rpm when climbing a fairly steep hill is important to remember though as it will definitely save you fuel
