Hi Guys,
I am a newbie here, but have been using this forum for some time and need some advice for an issue well covered here. I'm in South Africa, and we drive on the left (like the UK). I have 2 FIAT's an old 131 and a 2004 Stilo 1.9JTD(8V) with 96000km's on it. I am having a "Car Security, Loose connection fault" and the car will not start. After studying many threads on this issue, I have tried to sort it with the information that has been posted here. I have :
- Replaced the battery
- Replaced the Crankshaft Sensor
- Cleaned the D4 Connector
- Cleaned the 2 ECU Connectors
- Opened up the covers around the internal fusebox and checked connectors
- Bought a new battery for the key
- Tried the spare Key
- Checked and re-checked all earths with a meter
- Checked the antenna ring around the key
I believe this problem to be that the code is not getting to the Body Computer, and is inhibiting the car to start, am I right?
I downloaded FiatECUscan software but it won't connect to the engine management ECU (probably because the Body Computer is restricting it from operating) and I will have to purchase a licence as it won't connect to the Body computer without it. Will do that tonight...
I am unable to get it to a dealer, as the car is stuck in my garage, don't really trust the dealers.
Problem started intermittently and worsened to this point. The only work done on this car, recently, was an aircon recon as the aircon was making a noise and was overhauled and re-installed.
Can anyone help, I would greatly appreciate it.
Steve
Steve
