pc99
Climate Control - hot air on passenger side only
Has anybody else experienced this problem.
The climate control on my car has got 'stuck' twice now. When this happens, the passenger side vents blow out hot air, regardless of the temperature setting. Fiddling with all the controls has no effect, although the drivers side adjusts with the settings.
After switching off the ignition and coming back later, all seems okay again.
I assume that what is happening is that the passenger side vents are sticking in one position.
Just wondering if I'm the first.
