Technical Clutch noise
Hello :)
I have a Fiat stilo 1.6 from 2002,
I have like a clicking noise in the clutch, but when i press the clutch down, there is no noise at all, the noise from the clutch is only when i release the clutch and then the noise is there all the time until i press it down again,:bang:
any ideas what this can be?:idea:
Yeah well loads it could be !!
I guess it could be your thrust bearing on its way out maybe.
Sadly you may need to investigate further ie whip the box out if it gets too bad.
Good luck
Cheers,
Kev W
Do you mean you hear the click even when you don't press the clutch at all and the car is moving?
What about when the car is stationary and you're in neutral?
Maybe its an idle noise that's comming from the clutch area but it may be so many things. Does the click appear to come from within the car or somewhere under the bonnet?
