Technical sat nav
Technical sat nav
fueltank said:
anyone know how it works. where is the cd. does it interfear with cd playing. can you get it in mp3
The SatNav has the following features integrated into a single unit.
CD player (including MP3), Sat Nav, Handsfree GSM phone, Voice Recognition, Voice Guides, AM-FM Radio, Car Setup.
The unit has a single slot CD that you place either the Map disc or audio CD in. If you want to use Nav and CD player at same time the Nav unit loads enough route information into memory for you to eject the Nav Disc and then play an audio CD.
You can specify a 6 disc CD changer in the glove compartment which allows you to leave the Nav disc permenantly loaded in the head unit. However the CDC does NOT play MP3, this can only be done from the head unit directly.
Hope this helps
Paul
Stilo Multijet 140bhp said:
It's actually a 5 disc Cd changer and being used with the Sat Nav it has many, many faults!!! (Still worth it though)
Oops! - did I type 6 instead of 5 ?
Yes it does a have a few bugs, the must annoying being the fact it always starts playing track 1 album 1 when you start the car. But the SatNav and phone are well worth having.
