Technical Fog Lights
London
Hi all,
A while ago I changed all my bulbs (what a pain) for HID bulbs, including High Bean.
Since then although i'd never tried them previous tbh, they don't work. The lights comes on, on the dash but the fogs dont light up. The rears work, just not the fronts. Any ideas?
Cheers.
Checked your fuse front fogs F30?
If that's ok then everything can be checked at your relay T14 - power in- switch working- relay working- power out- resistance through bulbs- earth all without touching the bulbs
Potentially silly question, if you have never used them, are you sure they ever worked? On mine, with the lights on, if I have the headlights and front fogs on and I then flash the mian beams, the fogs turn off. Then when the high beams turn off, the fogs come back on. I assume they'd all be the same.
