Hi Guys.
Just popped in here in the vague hope someone might be able to shine some light on my 54 plate 1.6 Stilo.
Have two problems. First is a running issue. Car runs fine, apart from a slight mis which is noticeable when you accelerate, only a slight moss, not really noticable. BUT the amber engine warning light comes on when you start up and flashes up engine fault.
The car has developed a habit of cutting out occasionally and losing power, not revving over 2500rpm, we've found whilst going up hill.
Secondly is a knocking coming from the front end on slight bumps, have looked at droplinks, their ok and the top mounts seem fine, but havent disassembled for a look inside yet. The rear end has a nasty knock when going over a large bump which sounds like its bottoming out. Its had new springs all round last year and their all good/unbroken!
Im on the point of ordering up a new lamba sensor and a new coil, but any help or fault finding anyone can offer would be appreciated.
Im in Bristol if theres any local owners who fancy a tyre kick or use of my two post lift in return!
