FIAT Auto Specialist Team
Thread Tools
Old 17-08-2010   #1
mzhussein has donated!
Question steam from oil dip stick, missing oil?
Checked my oil today and it was about half, took a trip to halfords to buy 5L of 0w-40 mobil....20% off atm
when i got to halfords, it was pretty low...and there was steam (i think) coming from the dip stick hole, and oil filler...it wasnt gushing out, just whisping when i opened it...coolant isnt low, took about 1.5L of oil...just want to know whats happening? if its anything to worry about?
not worried about the oil consumption, its the only top up ive had to do in about 4 months, and its driven allot, over 12k done in about a year...
mzhussein is offline Reply With Quote Quote
Old 17-08-2010   #2
Yellow Peril has donated!
Re: steam from oil dip stick, missing oil?
Difficult to tell without seeing it, but hot oil can give off a vapour that could look like steam so probably nothing to worry about. If there was water in the sump, you'd see other evidence of it.
Phil
Yellow Peril
Then:Yellow Stilo 1.6 16V 3-door - not quite standard
Now: Red Stilo Abarth Schumacher GP Prodrive - modded for function over form...
Yellow Peril is offline Reply With Quote Quote
Old 18-08-2010   #3
Netherlands
You shpuld always wait a few minutes before checking the level. Give the oil the time to return to the sump after running.
When you checked the level before it was halfway (0.5 L) and after you drove to Halfords it needed 1.5 Litre?
You might have overfilled!
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 18-08-2010   #4
NobodyBlamesTheHappyGuy!
Morty Mort's Avatar
Trader Rating: 2
Morty Mort has donated!
Norway
There is pressure down there. The tube going from the engine into the inlet control valve releases the pressure. If this one is clogged, pressure will rise up the dipstick, but I don't think that's your problem - but worth ruling out.
On an earlier car I had there was a brass filter in this tube with really big oily deposits that required cleaning. Eventually I cut it off and put a little KN filter there. So the hot fumes never reached the throttle body.
jet blue. eibach pro system. omp bar. gsr in. supersprint out. hella eyes. phoenix gold watts.
member of the 5-door massive attack.
Morty Mort is offline Reply With Quote Quote
Old 18-08-2010   #5
Quote Originally Posted by Morty Mort View Post
That K&N filter sounds interesting Morty. I know the brass fiter you mean, but later cars don't seem to be fitted with one. Is the K&N a substitute? Any details?
Phil
Yellow Peril
Old 18-08-2010   #6
Morty Mort's Avatar
Trader Rating: 2
Norway
Quote Originally Posted by Yellow Peril View Post
I just measured the inside of the rubber hose / tube. Inserted a brass pipe with the correct diameter, letteing an inch stick out and bought a little KN filter to fit the outside of the pipe. Crank case venting is the name.
Here's a link.
http://www.knfilters.com/search/prod...x?Prod=62-1511
Old 18-08-2010   #7
i got to halfords, went in bought the oil, came out opened bonnet checked and filled...i think the 5-6 mins would be enough for oil to return to sump? i usually wait 1min for it all to "settle" ill go have a check in a min now that its cold and been left overnight...IF ive overfilled can i just extract it from dip stick hole?
Old 18-08-2010   #8
Morty Mort's Avatar
Trader Rating: 2
Norway
Quote Originally Posted by mzhussein View Post
Flip the car over and let it pour out the filler hole.
Old 18-08-2010   #9
ahhh i always wondered what that red button on the dash did....it filps the car! lol
Old 18-08-2010   #10
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Milwaukee make a tool to do that.
https://www.fiatforum.com/gallery/da...act_Wrench.wmv
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 18-08-2010   #11
Morty Mort's Avatar
Trader Rating: 2
Norway
Hahahahahaaa. Now that's an impact driver turnover tool. You need some torque in you waist aswell though.
Old 18-08-2010   #12
seboni121 has donated!
oil will be chucked around the engine,5 minutes is not enough to bring all the oil to the sump,I always leave the checking till the morning,you may have overfilled the engine,check in the morning do not start the car again leave for a couple of hours or morning,sure its about 4.7litres but depends on the engine size,never heard of the tool to extract from the dipstick hole,sound like a good idea,you may have a problem though the stilo hardly uses any oil,no leaks is there? or bigger problem on the way!
seboni121 is offline Reply With Quote Quote
Old 18-08-2010   #13
nice lol.....well have had a busy day, havnt actually driven today (is a rareity)....ill check it tomorrow....no tool to take out the oil, just syphon it out using a bit of poly tubing?
Old 19-08-2010   #14
had a little look last night before going out...and it was perfect, spot on full....so i wont have to flip the car
Old 19-08-2010   #15
sixpotman has donated!
My 1.8 has steam coming out of the dipstick
hole in similar circumstances, it is an hot
running engine and you can suffer burns
just wiping the dipstick when the engines
hot.
John
sixpotman is offline Reply With Quote Quote
Thread Tools
Steam from oil ROJ Lets Talk FIAT 4 07-05-2008 18:05
(T) steam coming in car fridayfeelin X1/9 5 26-08-2007 09:59
Steam Burster soap_dodger Gaming 6 25-01-2007 00:44
(G) Steam RiZZa Cinquecento / Seicento 2 03-12-2006 12:47
(T) steam secretmachine Punto (Mk1) 16 20-12-2005 11:48
