hi guys and gals
i thought i would prefix this tuning.
well i started to find my jtd was starting to get a bit smokey at around 2.5krpm. i asked the mrs to drive my car whilst i followed and yep it was smokey as hell, i then asked her to toe it up to 4krpm and i couldnt see her infront.
i know its an oil burner but that was bad, the car was still pulling like a train and wasnt missing at all.
anyways i solved the problem. i was thinking it could be an injector leak, air in fuel line, valve needing reseating, or a oil wiper gone on the piston rings, you get the idea.
my turbo pipes were cleaned only a little while ago when i had it all in pieces to replace various part and put an panel k&n filter in.
one word, tesco.......
yep tesco fuel is the problem, i original changed to asda and it cleared the problem almost immediatly, also the mpg went up by around 3-4mpg!!!.
i then tested with bp, and got a very similar result, better mpg and far FAR less smoking when toed.
i never belived all the hype about different fuel makes, i thought they were all basically the same, but it seems that tesco add some additive that isnt very good, i know they all put aditives in but tescos for me is now a big no no.
bp, or total fuel ive found to give best mpg, but they are usually slightly more expensive. im now running mine on 4 tanks of asda to 1 tank of bp / total whatever cheaper at the time.
anyone else found this, be it any of the supermarket suppliers?
roy
roy
