novatron1_2
Having now rebuilt my 1.2 16V which I bought with a failed head gasket (and water pump!) I'm a bit concerned about the idle speed. When you start from cold it sits at about 800 rpm and seems nice and smooth, then when it starts to heat up it drops down to ~750rpm and seems a bit lumpy.
I took it for its MOT today as I bought it with none, and the emissions test gave a speed of just 730rpm. I've also noticed that when slowing down for junctions, etc as soon as I dip the clutch it drops right down to just 500rpm, but doesn't stall.
I searched this forum and read through the "Cleaning Your Inlet Control Valve" thread but it looks different to the 1.2 16v throttle housing. Can I also over-ride the throttle plate servo to try and clean the housing, or will this damage the servo? Is it worth revving it whilst spray in some carb cleaner?
