Hi everyone
I was driving normally and went over a small-ish pothole and the airbag failure message appeared on my Stilo 02 5dr. Since then, it hasn't disappeared and I've tried wriggling the wires under the seats but hasn't done anything.
Before I rush out and buy contact cleaner (as per the guide), is there an easy way to test which airbag connector could be causing the problem, assuming of course it is a connector problem.
Could I possibly disconnect the orange connectors individually then turn on the ignition to see if the error message disappears? Or would it still throw up the error even if all orange airbag connectors are disconnected? I want to try and eliminate all of the connectors before I take it to the garage tomorrow.
