re: Won't Start [possible faulty ECU?]
battery is good but will try the disconnect as well
first time posting today tho been a lurker for a while and would like to thank all for there replys
Body computer?
That's behind the drop down panel next to the steering wheel, where you can see the fuses
I'd try an ECU reset by disconnecting the battery for an hour and see if it sorts itself out. I'd check if you've got a healthy 12.5v at the battery too whilst it's disconnected
