4th April had flat battery. Not surprised as 4 years old. AA patrol got me going, said alternator is fine, battery not holding charge. Got myself to Halfords who replaced battery.
All ok, then 10th May left car at airport while on holiday. Came back two weeks later. Flat battery! AA patrol again got the car started, tested alternator and again was charging battery but he tested the battery with a meter and said it wasn't holding charge. Print off stated 'replace battery. So I went back to halfords and told them my 8 week old battery is a dud. They then tested it with their own meter and it passed. The blokie said it is holding 72% charge which while low for a nearly new battery, is not low enough to indicate a maufacturing fault. I was not happy to get two contradictory 'expert' reports, but bottom line is that Halfords refused to relplace the battery.
So now I'm thinking of taking it to Fiat to see if there could be an underlying problem causing this lack of full battery charging. If the alternator is working as the AA stated and the battery is not faulty as Halfords stated, then what else could it be?
Before I take the car to Fiat and get bamboozled with pseudo-science which ends up with me being relieved of £1000 for them to stick a bit of tin foil to a bit of wire, does anyone know possible causes so that I can go to Fiat without appearing to be totally gullible.
Ta!
Ta!
