Technical !!swimming pool of water under my stilo!!
StealthStilo
bradford
hi guys a got a 1.2 stilo!!! i dont know if this picture will work but this is were my leak is coming from is it a water pump??? thanks
if this picture doesnt work i will explain :bang:
Am I missing some thing here the veiw show an 8v engine and not the 16valver in the 1.2 are you in the wrong section..:confused:
Help custard heeeeeeelp..
sorted mate!!! my waterpump is leaking then!!
Only way to confirm it is the pump 100% is to visually inspect it..get the cam belt covers off to see if its weeping or clattering..if it is its the start of a big job..not just the pump but the cam belt and tensioner should be sorted at the same time..the 1.2 pump runs off the cam belt and may be contaminated as well..:(
