Old 05-05-2010   #1
Donkey has donated!
how hard is the throttle body to remove on an abarth??
as the title says, any tips??
wanted to get it off to give it a proper clean and check what the pin in the inlet manifold looks like.
also, where can the selespeed lose oil?? i had to top it up about half a liter this morning!!!
Not so much a panda, more of a grizzaly bear. GRRRR
Donkey is offline Reply With Quote Quote
Old 05-05-2010   #2
has pooped his pants
Greggers's Avatar
Greggers has donated!
Re: how hard is the throttle body to remove on an abarth??
Quote Originally Posted by Donkey View Post
I've got the eLearn proceedure here which I can post if you want it. I just need to fire up my Windoze laptop rather than the Mac I'm on now
Basically though, it's as follows:
  1. remove coil cover
  2. remove battery cover
  3. remove battery negative terminal
  4. remove the ECU
  5. remove the induction rigid pipe from the throttle body
  6. disconnect the electrical connection for throttle body actuator
  7. undo the earth cable on the throttle body
  8. undo the 4 botls that hold the throttle body to the inlet manifold
All done!
As for your Selespeed leak, are you seeing any oil under the car? Half a litre is a fair bit for the Selespeed The best bet is to get under there and have a good nose around and try and track it down
'02 Stilo Abarth 5 Door
18" OZ Wheels, Prodrive GP Suspension,
Brembo Gran Turismos, GTA Injectors, GSR & BMC CDA, Red-Dot Remap, Custom De-Cat Exhaust
Garage
Greggers is offline Reply With Quote Quote
Old 05-05-2010   #3
Donkey has donated!
ahhh yeah that would be top, cheers for that.
i had to top it up about a year and a half ago and i had loads of work done to it at clovertech with the engine been ripped out so i dunno what the level was after all that.
last time i had to top it up it was throwing a wobbly every so often until i topped it up, however, 5 min down the road from my house this morning and it took itself out of gear and wouldn't go back in. it hasn't missed a beat for ages before then, the oil level was below the top pipe on the tank! i was amazed how it lost so much so quick, but i just topped it back up and she worked fine and hasn't lost any now. bit of a head scratcher.
Old 06-05-2010   #4
Greggers's Avatar
Here you go!
Garage
Old 06-05-2010   #5
Donkey has donated!
top stuff, you posted it just as i had finishing installing my injectors so i took it off and gave it a clean.
cheers
(G) swapping throttle body EASY? or HARD? corky Punto (Mk2/2b) 25 02-10-2009 13:26
(T) Throttle body redfairy Punto (Mk2/2b) 12 13-07-2006 19:11
(T) 105 JTD - Where is Throttle Body / Throttle Potential Sensor b1gduk Marea 4 22-01-2006 20:53
(T) Throttle Body ?? crazy_cinq! Cinquecento / Seicento 13 12-04-2005 14:53
(T) Throttle Body Mr Brown Cinquecento / Seicento 12 07-10-2004 13:18
