FIAT Auto Specialist Team
Old 12-03-2010   #1
intermittent illumination of engine warning light
Hi
Wondered if anyone could offer me any advice?
I have a 55 1.6 stilo multiwagon and every now and then perhaps once a week the engine warning light comes on, the light generally goes off when ignition restarted after a short time, there is no change in how it drives, its recently been serviced and fluid/oil levels seem fine.
What could this be? Could it just be a gremlin?
Any advice appreciated
karen
miss fiat is offline Reply With Quote Quote
Old 12-03-2010   #2
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Re: intermittent illumination of engine warning light
Hi. Welcome to the FF.
For an intermittent fault like this, you would need to get the fault codes read from the car.
Your garage that serviced the car should be able to do this or you could buy your own fault code reader for about 30.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW) - 5 of 215/45-17 Alloy Wheels
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 13-03-2010   #3
Thank you Davren, will do
Could a low battery do this? I'm still using original battery ( dec 05 ) seems fine but was wondering due to age if i should get a new battery
Old 13-03-2010   #4
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
A low battery wouldn't cause the engine fault light to come on while you're driving. The alternator takes over supplying all the electricity the car needs once the engine has started.
Having said that, if the battery is 5 years old it may need replacing anyway.
(T) Power loss and intermittent fuel injector warning light problem. HELP! Ashley99 Tipo (Classic) 1 24-06-2009 14:44
(G) ABS warning light intermittent illumination andrew1620 Ulysse 0 09-08-2008 17:33
(T) Oil Pressure Warning light (intermittent) OnLyZ Stilo 14 13-04-2007 09:02
(T) New problem! Intermittent brake warning light?! Suz359 Punto (Mk2/2b) 2 03-07-2006 21:14
(G) Intermittent Battery Warning Light MotorWorldChink Cinquecento / Seicento 5 30-09-2004 19:33
