Right, Have had the brake light switch replaced and the fault remains P0703 and wont clear and the garage have said it might well be a ecu fault as the boost fault is still there too but only after i give it some stick.
Would cleaning the D4 and the other connectors help as have bought some contact cleaner from hafords tonight. What about cleaning the contacts to the ecu which i assume is the box sort of front left in the engine bay near the header bottle.
Any other suggestions as it is really really P***ing me off now and any ball park fiqures for the ecu if it is that. Im guessing if the ecu is on the way out that would also be why there is a boost valve error too?????
Thank you.
Thank you.
