Thread Tools
Old 20-02-2010   #1
Alfa 145 2.0 20V Turbo
B3NNETT's Avatar
B3NNETT has donated!
ESP/ASR retrofitting??
Right I have been thinking about this idea for a while and I'm just wondering if it is actually possible.
I would like to add ESP/ASR to my 06 stilo 1.9 jtd mjet sporting 120
I have had a little thought and I think it would involve a fair bit of wiring to get it to all the abs sensors etc but if I could get the system of a car that's being broken, do you think there would be any other problems like if it would have to be tied into the body computer or CAN network?
I thnk if this is at all possible I think it would be a great little project.
Any help appreciated.
B3NNETT is offline Reply With Quote Quote
Old 20-02-2010   #2
12[X] has donated!
Re: ESP/ASR retrofitting??
abs/esp/asr is one unit - i'd be guessing that although your ecu would not talk to it and may give you a flashing mileage display (am also guessing it is a smart node) abs and esp would work (as these mainly control the brakes) but i don't see how asr would work as it needs to talk to other components to control the clutch (if your car can even do that) hm come to think of it.. esp would also need to control the clutch (or at least the accelerator) i do not see it working as a retrofit with original equipment – but do give it a go (would be quite interesting to find out if i’m wrong)
12[X] is offline Reply With Quote Quote
Old 20-02-2010   #3
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
This has been discussed at length before and the general consensus is it's a complete waste of time (usual body computer issue)
That said I don't think anyone has gone to the trouble of trying so you're welcome to be the first - but don't say I didn't warn you
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 21-02-2010   #4
B3NNETT's Avatar
Thanks for the quick reply, I'm thinking that the way it controls the power would be more the throttle through the throttle position sensor, and possible braking the wheels through the abs system,
I'm going to have a look at the elearn just to have a look to see what the system actually plugs into and then hopefully it may be a case of just runnng wires etc.. As depending the ecu may be already programmedwith it and just needs waking up.
I will definately be giving it a go if I can get hold of a car for braking or all the neccessary components.
Old 21-02-2010   #5
B3NNETT's Avatar
Quote Originally Posted by Argonought View Post
Had a quick search and can't find anything about retrofitting it, have you got a linky?
Old 21-02-2010   #6
Moderator
Davren's Avatar
Trader Rating: 5
Davren has donated!
Quick browse of ePER suggests the brake servo, master cylinder, ABS modulator and ABS ECU are different. I suspect the engine management ECU could also be different.
Stilo Parts For Sale: Connect Nav+ Map Discs - Wiper Motor (NEW) - JTD/JTDM Front Brake Discs (NEW)
For details, click here: http://www.fiatforum.com/classifieds...0&ppuser=48514
Davren is offline Reply With Quote Quote
Old 21-02-2010   #7
B3NNETT's Avatar
just been having a quick look at Elearn, and it seems that all the components needed to run the asr system are already there, the only thing i can see is possibly having to change the abs control unit and fit the asr on/off switch, seems like the wires and sensors for the rest are standard things with abs anyway,
The ABS electronic control unit M50 is supplied (at pin 2 and 6) directly by the battery via a line protected by maxifuse F1, housed in the engine compartment junction unit B1.
The ignition-operated supply (INT/A) reaches pin 23 from the line protected by the fuse F42 of under facia control unit B2 .
The control unit is earthed via pins 1 and 5.
The four sensors K70, K71, K75, K76 send wheel speed signals to pins 28-12, 15-16, 13-14 and 30-31 of M50 respectively.
Brake pedal switch I30 sends an enablement signal to pin 14 of control unit M50 : the ABS cannot intervene unless the brake pedal is pressed. The switch I30 is supplied when the ignition is switched on (INT) from fuse F37 of junction unit B2 .
The 'ASR OFF' control button on panel H35 sends a deactivation signal to pin 27 of M50 , while pin 18 viene relays a signal that turns on a led on panel H35 when the system is off. ; The switch H35 is supplied when the ignition is switched on (INT) from fuse F49 of junction unit B2.
Pin 37 of M50 emits a discrete speed signal for transmission to Body Computer M1 ; the same signal is also copied to the CAN network.
Pins 24 and 40 of ABS control unit M50 connect to engine control unit M10, Body Computer M1 and and instrument panel E50 to control the ABS warning light and - if the problem lies in the EBD function - the low brake fluid level and handbrake warning lights.
The ASR function manages the relevant warning light as described previously.
Self-diagnostic data can be read by connecting to connector C of Body Computer M1- pin 1: it receives signals from pin 11 of the control unit M50 via the special diagnostic line.
Old 21-02-2010   #8
Argonought's Avatar
Quote Originally Posted by B3NNETT View Post
I can't find the one I was thinking of (maybe mistaken )
but you might find this an interesting read:
https://www.fiatforum.com/stilo/43417-esp-got-not.html
Old 22-02-2010   #9
Thanks for the quick reply, I'm thinking that the way it controls the power would be more the throttle through the throttle position sensor, and possible braking.
A JTD doesnt have a throttle like a petrol. The system has to tell the engine ECU to reduce fueling and no, it does not apply the brakes.
I think it would be easier to sell the car and buy one with it fitted if you really want it.
john55 is offline Reply With Quote Quote
Old 22-02-2010   #10
B3NNETT's Avatar
The actual throttle pedal is the same operation just how it comes out the ecu the other end that's different.
It was my understanding that ESP braked individual wheels to stop the car spinning whereas asr just cuts the throttle to stop wheelspinning.
I am more intrested in getting ESP than asr although both would be nice.
I still think this would be possible with a little more research,
Old 22-02-2010   #11
Argonought's Avatar
I think you need to do a bit more reading before you start.
Since ASR is a subset of ESP then that's effectively impossible
As has been suggested, I'd go the new car route
Old 22-02-2010   #12
Trader Rating: 2
danhans115 has donated!
Andorra
And usually when something retrofitting has the words CAN involved - it usually CANnot be done that easily.
Sorry its a monday and Im struggling for jokes
If it aint broke, break it and fix it anyway
Former Abarth Owner
danhans115 is offline Reply With Quote Quote
Old 22-02-2010   #13
Netherlands
You were already in the CAN?...
gr J
"Look for the ridiculous in everything and you will find it". - Jules Renard
A3jeroen is offline Reply With Quote Quote
Old 22-02-2010   #14
adamcot has donated!
I don't think he meant he didn't want the ASR, he meant that ESP will be more useful to him. By looking at Elearn, no diesel Stilo manufactured after 2004 even had the option of the systems? Therefore "new car route" to the same specification is impossible.
I think its worth a go at anyway as the parts will be available used cheaply, no one else seems to have even attempted it, how do you know until you try something
Porsche Boxster S, Abarth 500
adamcot is offline Reply With Quote Quote
Old 22-02-2010   #15
B3NNETT's Avatar
yeah thats what i meant thanks ads,
yer i like to have a challenge and be the first its what makes me tick lol.
if anyone would like to help would be nice to have a pic of the abs pump/modulator with esp/asr to compare the differences and part no. if it is on it.
Thread Tools
(G) ESP/ASR Error FlodNar Ulysse 12 04-02-2013 21:55
(T) Esp/asr bravo jtdM150 Bravo 22 23-12-2009 20:57
(T) ESP/ASR/Selespeed kevinbarr Stilo 3 08-03-2009 12:57
(T) install ESP/ASR? davkar 500 2 23-12-2007 19:53
(T) ASR and ESP Failure Graham Lane Stilo 12 30-08-2005 11:12
