Might I suggest you search through the others treads, possibly the I.C.E. forum. Start
here
But to recap:
As far as choosing the components, it's down to personal taste and is a case of suck it and see. Go somewhere you can audition speakers, e.g. your local ICE store, or Halfords. Your choice will depend on the sound you are looking for (and your wallet). This will also dictate the price. High sound quality will be expensive, but 'bang and fizz' will be cheaper.
It will not always be possible to audition speakers, so reading peoples comments in fora like those found
here may be your only option.
I didn't have the oportunity to audition the Kenwoods which I chose. My purchase decision was based on help by the staff at my local ICE emporium. Unfortunately, I am not really that happy with them. Then again, I am comparing them to my home hi-fi which cost considerably more. However, they are better than the OEM speakers.
I know Infinity get good comments and they can be bought easily from Halfords.
As for buying on-line, check out the stores mentioned in
this thread.
Right, fitting. I would recommend taking as long as possible doing this. You are less likely to make mistakes or damage things.
The tweeters are relatively easy to replace. The housings are on poppers (see pictures on my website - links in thread highlighted above). The tweeter connecters are clipped in, so don't just pull them
With the housings clear, you can remove the tweeters. The Kenwood tweeters I used required larger holes, so I drilled them larger.
I will have to stop there for a bit. I am at work and shouldn't really be on the net this long [:0]
Actually, what I think I'll do is write a 'How to...' on the whole process, add a few pictures, then make a post. I'll be replacing the rear speakers (3-dr car) over the weekend.
_________________________
2003 Stilo 1.6 Dynamic 3dr, Orion Grey, 17" Alloys, Dual Zone Climate Control, Aluminum Sills, Clarion DXZ928R, Kenwood DualMags, Clarion SRX1784, almost de-badged (just grille to go).
I accept no responsibility for anything contained in my posts, or any decisions you make based on them.[^]
