- Oct 3, 2006
- 68
- 23
Hi All,
I've just been getting annoyed at my Stilo.
Been running on three cylinders again.
Last time replacing the coil fixed it.
But this time it didnt.
So I replaced the spark plugs, swapped round the coils and accidently blew a fuse.
Whilst trying to check the engine bay fuses I managed to remove the fuse without its legs.
So... I removed fuse box and dismantled.
Cleaned up the corrosion and replaced one set of contacts with an external fuse holder.
Also checked ECU to Coil connectors wiring with meter. ( all ok )
Next decided to dismantle the ECU and repair.
A few pictures attached showing the cleanup of the battery bay wiring and fuse box dismantled.
Will update as I repair the ECU.
Mark
BTW: If anyone has a naff ECU going spare... I need atleast one VB326 or VB325 ignition chip. ( one of the four things on the right hand side of the ECU picture ), ST have them but min order is 740 of them !!!
s8.photobucket.com/albums/a21/bigfathairybiker/Stilo/
Mark
