Thinking of removeing the climate control from the MW and replacing it with the basic heating control out an active . is it as easy as just swapping them over ? cheers mick
You would need to replace the complete heater/air conditioning unit behind the dash/center console. The flaps in the basic heater are cable operated whereas for the climate control system, they are operated electronicaly by stepper motors.
Dave.
It closes the air recirculation to outside air flap so you don't get the smell the windscreen washer fluid.
Same for the speedometer signal, it's supposed to close the flap if you're going less than 10 kph so you don't get exhaust fumes from the car in front.
2 more for the "Things you didn't know your Stilo did" thread.
Dave.
Dave.
Never worked to me so far... And neither any action when i open my skywindow...
Are you sure about that?
