Glove Box Lid - Info & Help With Part Find Please!
Hi -
I had a broken glovebox hinge (as discussed in www.fiatforum.com/stilo/92478-stilo-storage-above-glovebox.html). Decided to fix it, and after a mammoth struggle was finally able to remove the lid/hinge assembly. As described in the earlier thread, it was a nightmare of slow fiddly work with a mirror and torch, and various small torx drivers. I'm happy to post more info about that if anyone's interested, but there's no technical complexity it's just horribly tight and restricted in there.
Anyhow, when I refit I'm going to use nut-headed fixings which will be a lot easier that the rubbish torx screws. Flush fitting does not appear necessary, so will probably weld 10-20mm of hex onto each torx screwhead so it can be located and turned more easily. Will report on the success of that in due course.
Main reason for this particular post is to request help with identifying the new part needed. Old assembly is as photo, and I need to replace it all (some damage during removal...). Please can anyone help with a parts reference (and price would be a bonus) for the complete assembly as in photo? 2004 5 door JTD aircon, vehicle 448121.
Eper diagrams bear no resemblance at all - part 71728346 has no hinge parts, and no panel for fixing to the underside of the dash. Elearn workshop manual only has the removal of the trim panel (procedure 7040A52 UPPER DASHBOARD ODDMENTS COMPARTMENT FLAP COVER - R.R) but at least the parts are correctly drawn.
(edited to add elearn graphic)
Hi -
