I have a problem with the reverse white lights: it doesn't start when I put the gear shift lever into the reverse. The problem it seems that is not from the fuse or the bulbs , because I have check and everything is ok. Can anyone tell me wher is the reverse gear swith? Because I have searched near the gear shift lever and I do not found it.
Thank you!
Best regards,
Vicentiu.
P.S. The car is Fiat Stilo 1.9JTD Coupe
Thank you!
Best regards,
Vicentiu.
