Thread Tools
Old 04-09-2009   #1
Netherlands
Unhappy Parrot MK6000 & Loose connection error
I've installed a parrot MK6000 in my Fiat stilo. About 1 out of 10 times when the parrot unmuted the radio I got a "Loose connection" error on my Stilo dashboard.
The suddenly after about a week the parrot died. I got a new one, and this time I decided to let a professional install the parrot. But now I still get the "Loose connection" error, and I'm affraid it will kill my parrot again eventually.
The parrot works fine (apart from stuttering audio from my 3GS once in a while), and it shuts down properly after removing the key from ignition.
Can anyone shed some light on this problem? It wil be greatly appreciated!
generator is offline Reply With Quote Quote
Old 06-09-2009   #2
Netherlands
Re: Parrot MK6000 & Loose connection error
Update: When the error pops up, the speed indicator goes flat.
Old 07-09-2009   #3
It's about GO! not SHOW!
Argonought's Avatar
Argonought has donated!
Sounds very much like you've interfered with the CAN network.
There are two connections (?) on the oem radio which should never be wired to anything else
Stilo Dynamic 5 door JTD {150} 02 model in Metallic Grigio Steel with Skyroof & 16" Alloys Mods: New standard springs all round; Tyres: FALKEN ZIEX ZE912; Oil: Mobil 1 TD 0W-40 fully synthetic
Argonought is offline Reply With Quote Quote
Old 07-09-2009   #4
Netherlands
Hm... do you know which connections, so I can check if they're wired to anything else?
Thanx
Old 07-09-2009   #5
Argonought's Avatar
Old 08-09-2009   #6
Netherlands
Thanks, i'll have a look!
Thread Tools
(T) Won't Start & Loose Connection Problem [ECU bad contact] White_Rabbit Stilo 15 03-09-2014 15:53
(T) Loose Connection juan Stilo 6 10-12-2010 10:08
(T) loose connection on 2.4 anthonytutton Stilo 25 29-09-2007 21:45
