I am having a bit of a nightmare trying to trace the fault....any ideas?
Symptoms.
when main beam is flashed (with lights side lights off)....am getting a low brake fluid warning, quickly followed by N/S/F indicator bulb.
Very annoying
Brake fluid is fine, all bulbs good. Have cleaned up brake fluid sensor connection and all connected connections. Still problem persists. Has anyone come across this and if so, what connection does the fault lie in....
I am a Electronics Engineer, so please no replys telling me to check what i already have checked, am looking for some sound ideas to where the fault could be loacated, without having to do a rewire
Symptoms.
Very annoying
