Thread Tools
Old 19-08-2009   #1
PAULH has donated!
Leaking CV Boot Joint
Hi
I had to get my tyre replaced and was told by Kwik Fit that the off side CV Book Joint is leaking. They quoted 50 to replace, is this something I need to do asap or is it something I can live with for a month or 2?
They also put on a budget tyre and it doesn't feel the same as before to drive, can I tyre change this?
Paul
PAULH is offline Reply With Quote Quote
Old 19-08-2009   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Leaking CV Boot Joint
Quote Originally Posted by PAULH View Post
Hi
Paul
Hi Paul, KwikFit should be a last resort really IMO, but its done now.
I had a CV joint gaiter replaced for 35 by a trusted mobile mechanic. Its not something you should leave as the joint will lose all its lubrication grease and get grit in it, causing rapid failure of the constant velocity joint, plenty more expensive! I believe it is always better to change both tyres on the same axle for the same type if you can stretch to it, different tyres may have different grip characteristics, particularly in the wet.
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 19-08-2009   #3
sixpotman has donated!
If it's only a small hole and on a flat area
clean the boot off and use a cycle punture
repair patch and glue to cover the hole as a
"Stop Gap" untill you can get the boot
replaced.
Any water or grit that gets into the CV joint
wil cause serious wear and the joint will need
replacing.
Some of my temporary repairs have lasted
years and passed MOT's ok
John
sixpotman is offline Reply With Quote Quote
Old 21-09-2009   #4
PAULH has donated!
Hi
Took this to proper garage rather than Kwikfit and was fixed for minimal cost! Not the 45 as recommended by Kwikfit!
Thanks for your help with this subject.
Thread Tools
(T) CV Boot and pot joint removal jiminwatford Cinquecento / Seicento 9 21-03-2009 13:19
(T) Leaking from CV joint boot awattam Cinquecento / Seicento 11 31-05-2007 19:29
(T) Ball Joint Boot Repair UKKid35 Barchetta 0 29-05-2007 01:58
(G) Leaking Boot!! floppsybear Punto (Mk1) 2 21-02-2006 21:38
(G) Leaking Boot blondblackbrunette Cinquecento / Seicento 15 02-11-2004 00:00
