Hi all
I have a 2.4 55 plate stilo which is baffling me . The clutch pedal loses pressure and then returns as i am driving . There are no leaks , no loss of fluid from brake pot as it is still the same ,the gears change but are not as smooth as they should be . . It seems worse as i go faster and returns when i slow up or use the brakes.
Have even put card board under car to check for slave leak and ther is none. Could a blocked vent on brake cap cause this sucking air in from weak joint .
regards
kewi
regards
kewi
