The easiest way is to pull the carpet trim back until you can get access to the rear light. Then remove the 3 10mm nuts that hold the lamp in. Once out the rear bulb holder just clips out of the lamp.Make sure you put the right wattage bulb in otherwise it will say you have a bulb out all the time.
