Was driving it today and it took about 15 minutes of regular driving before light came on and temperature gauge was off the scale... I let it cool for 15 minutes and drove it home with the windows down and hot air on full.
My coolant level always remains the same and the fan kicks in while im driving. It doesn't overheat while stationary and the pipe which looks like it leads to the radiator is very hot after driving but the pipe leading away remains cold...
Any advice on the problem, my guess is an airlock or water pump failure?
Does the stilo have a bleed valve on the radiator?
A separate issue is that most days it displays 'Stop' 'engine oil low' even after topping the oil up? yet it always runs fine.
Thanks for your help
A coil went last week and found that my alloy had cracked
