john55
Established member
I intermittently get the ABS pump activating (I can feel it through the brake pedal) under normal or light braking. I also get ABS/ ASR failure warning coming up intermittently after driving for a bit (Not at the same time as the ABS is activating), usually on a corner, U turn etc. I have cleaned all the connectors in the system, removed the ABS sensors themselves and cleaned them. I don't get any warning on startup, just randomly later on. It could be after driving 10 meters, or 50 miles. I have checked the brake lights and they work normally so I dont think it is a switch problem. I have even taken each wheel off in turn, turned the wheel and heard the beep-beep of traction control actvating, then pulled and twisted the wire to each ABS sensor but have not been able to get a failure by doing this.
Any suggestions?
Any suggestions?
