hi can this be stuck as a sticky info on swirl flaps and actuators.ta
http://www.ms-motor-service.com/ximages/pg_si_0093_en_web.pdf
whats the purpose of a swirl flap?
Basically it turns your 16V engine into a 12V engine at low RPM. Blocks 4 inlet ports which makes the air mix better with the fuel as it is injected. Air enters the chamber at higher speed (through only one valve) and swirls inside the cylinder, aiding efficient combustion at low load / low speed conditions. When more power is required, the swirl flaps open and it becomes a 16 valve engine.whats the purpose of a swirl flap?
I don't think any production petrol engine needs them yet to meet euro emissions standards. I think they are still in development by manufacturers. They will not actually fit them to cars unless forced to by new Euro standards, because it all adds cost. I could be wrong though.do the t-jet petrol engines have them or just derv?
here some pics of bits you wouldn't expect to see for a few years yet.
photos of star jets bits
plastic starjet throttle body even the butterfly is plastic
soon they be making plastic engines :bang:
Well, they have made into petrol engines already.i don't know what the systems are like on the BMW, but glancing at the GM solution shown in the PDF - they're a bit clunky and over the top for what they need, and FIATs solution is better and much less prone to breaking. I would be suprised to hear of a failure where debris enters the cylinders
I've just had a horrible thought. Does the Abarth 2.4 engine have these flaps? This item:
http://www.fiat.com.sg/defaultf5b3.html?MenuId=69
talks about a variable geometry intake manifold. And there is some sort of device on the end of the manifold opposite to the throttle valve...
