Hi guys,
My Abarth has a slight oil leak (a drop or two overnight) which isn't a problem in itself but I would like to get it fixed at some point. My question is, what work needs to be carried out to repair it?
The leak itself is coming from behind the flywheel bell housing and at a guess, I'd say that it is either the crankshaft oil seal, the balance shaft oil seal or an oilway plug leaking. To fix it, what needs to come off? What's worth replacing at the same time? And is it worth changing the diff to a Q2 at the same time as well or can that be carried out seperately? :slayer:
Cheers!
Greggers
Cheers!
Greggers
